[postgis-users] Transform Coordinates
Nicolas Ribot nicky666 at gmail.com
Wed Nov 12 02:42:39 PST 2008
> How can I transform the coordinate system of a table ?
> I know the SRID is 4326.
> Thanks a lot
Basically, by using st_transform(geometry, srid) on your table.
It may be a little more complicated if you have SRID constraints on your table.
2 options among several:
1°) Drop the constraint, update your data by transforming them, readd
the constraint with updated SRID value
2°) Add a new geometric column to your table and insert into it
transformed geometries from the first column.
HTH
Nicolas
