[postgis-users] Transform Coordinates
lisek lichu lisek.lichu at gmail.com
Wed Nov 12 10:15:42 PST 2008
WOW i didn't know that
Thanks a lot :P
On Wed, Nov 12, 2008 at 18:16, Jean David TECHER
<david.techer at davidgis.fr>wrote:
> The two options are right but becarefull with the second!
> You will have to do something like
> ALTER TABLE ADD COLUMN ...
> Because of  the remarks taken from PostgreSQL doc
> "Adding a column with a non-null default or changing the type of an
> existing column will require the entire table to be rewritten. This may take
> a significant amount of time for a large table; and it will temporarily
> require double the disk space."
> So check that's you have enough space if your table is very big
> Please see http://www.postgresql.org/docs/8.X/static/sql-altertable.html
> where X=0,1,2,3
> --david;
> Quoting Nicolas Ribot <nicky666 at gmail.com>:
>  How can I transform the coordinate system of a table ?
>>> I know the SRID is 4326.
>>> Thanks a lot
>> Basically, by using st_transform(geometry, srid) on your table.
>> It may be a little more complicated if you have SRID constraints on  your
>> table.
>> 2 options among several:
>> 1°) Drop the constraint, update your data by transforming them, readd
>> the constraint with updated SRID value
>> 2°) Add a new geometric column to your table and insert into it
>> transformed geometries from the first column.
>> HTH
>> Nicolas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Jean David TECHER
> www.davidgis.fr
> 06 60 46 85 05
> 04 99 77 16 87
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081112/7a523f37/attachment.html>
