[postgis-users] PostGIS 1.3.4 RC3 released
Kevin Neufeld
kneufeld at refractions.net
Thu Nov 13 09:33:32 PST 2008
I'm trying to compile it with PostgreSQL 8.2.4 with no luck.
I did this (configure and make had no errors):
./configure --with-pgsql=/opt/pgsql-test/bin/pg_config
make
make install
Yields this as an error during install:
mkdir: unrecognized option `--prefix/share'
Try `mkdir --help' for more information.
make[1]: *** [install-lwgeom-scripts] Error 1
make[1]: Leaving directory `/usr/local/src/postgresql-test/contrib/postgis-1.3.4rc3/lwgeom'
make: *** [liblwgeom-install] Error 2
Looking back, I realized the config.log had this:
configure: creating ./config.status
config.status: creating Makefile.config
config.status: WARNING: Makefile.config.in seems to ignore the --datarootdir setting
config.status: creating config.h
SUMMARY
HOST_OS: linux-gnu
PGSQL: /opt/pgsql-test/bin/pg_config
GEOS: /usr/local/bin/geos-config (with C-API)
(ldflags: -L/usr/local/lib)
PROJ: prefix=/usr/local libdir=/usr/local/lib
ICONV: 1
PORTNAME: linux
PREFIX: --prefix
EPREFIX: ${prefix}
DOC: --prefix/doc/postgresql/contrib
DATA: ${datarootdir}
MAN: ${datarootdir}/man
BIN: /opt/pgsql-test/bin
EXT: /opt/pgsql-test/lib (\$$libdir)
It looks like for some reason the PREFIX did not get it's variable defined.
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Hi everyone,
> The PostGIS team are pleased to announce that PostGIS 1.3.4 RC3 is now
> available for download from
> http://postgis.refractions.net/download/postgis-1.3.4rc3.tar.gz.
> In particular, the team are interested in confirmation that the
> regression tests ("make install; make check") run on the following
> platform combinations:
> PostgreSQL 8.1+ - Win32
> PostgreSQL 8.1+ - Solaris
> PostgreSQL 7.3 - Linux
> PostgreSQL 8.1+ - GEOS 2.2.3 - Linux
> PostgreSQL 8.1+ - GEOS 3.0.3 - Linux
> PostgreSQL 8.1+ - GEOS 3.1 - Linux
> If you are one of the first people to test one of these platforms, or
> experience a regression failure, please feel free to post the relevant
> "make check" output to the mailing list.
> Happy testing!
> ATB,
> Mark.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081113/b555aa76/attachment.ksh>
