[postgis-users] Problem in migrating shapefile to postgis
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Fri Nov 14 06:30:37 PST 2008
You should still be able to load this data into postgis, it will default to SRID -1 if you do not include the –s switch.
Once inside postgis, you can then gain at least some information about the data by querying the extent(the_geom) of the table. That will tell you if it is in some sort of lat/lon projection (coords between -180 and +180), or if it is some sort of metric system (very large numbers).
If it is in a lat/lon system, then you should be able to get it to work approximately, with some lat/lon projection that works in your area.
HTH,
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Burgholzer,Robert
Sent: Wednesday, November 12, 2008 12:53 PM
To: nguyenquangvinh20052005 at yahoo.com; PostGIS Users Discussion
Subject: RE: [postgis-users] Problem in migrating shapefile to postgis
First place to start to find the proper SRID is look for a metadata file for your shape. If you have that, you may post on the list, perhaps someone can help.
r.b.
804-698-4405
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of vinh nguyenquang
Sent: Wednesday, November 12, 2008 12:36 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Problem in migrating shapefile to postgis
Hi, everyone
Can you help me load LopGiaoThong.shp vao trong postgis? I have problem
with SRID or something else i don't know.
I do it in this way: shp2pgsql -i -D -s LopGiaoThong.shp LopGiaoThong >
LopGiaoThong.sql
psql -d postgis -U postgres -f LopGiaoThong.sql
I do not know the parameter -s: what value it is to load LopGiaoThong.shp
Can you show mw how to find the value of -s parameter (SRID) of my data or
how to load my data to postgis?
Thank you very much!
Re: I still can not load LopGiaoThong.shp to postgis. Even though, I tried with -s parameter: 32648, 4326, 3405. I really can not find the correct SRID's value of my data. I really appreciated if anyone can help me do it.
Thanks!
_____
Nước nào thường cho nhiều học bổng du học? Khám phá tại Yahoo! Hỏi & Đáp <http://sg.rd.yahoo.com/mail/vn/footer/def/*http:/vn.answers.yahoo.com>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081114/0f1f6eba/attachment.html>
