[postgis-users] Newbie question - remove duplicate / identical feature in postgis
Intengu Technologies
sindile.bidla at gmail.com
Fri Nov 14 08:00:23 PST 2008
Dear Kevin & Jean
Thanks for the assistance.
2008/11/13 Kevin Neufeld <kneufeld at refractions.net>
> Unfortunately Jean, this won't work. Your unique constraint on the
> geometry column is using the geometry equals operator (=), which compares
> the bounding boxes of the geometries, *not* the geometries themselves.
> I.E.
> postgis=# select 'LINESTRING(0 0, 1 1)'::geometry = 'LINESTRING(1 1, 0
> 0)'::geometry;
> ?column?
> t
> (1 row)
> postgis=# create temp table tmp (geom geometry);
> CREATE TABLE
> postgis=# alter table tmp add constraint unique_geom unique (geom);
> NOTICE: ALTER TABLE / ADD UNIQUE will create implicit index "unique_geom"
> for table "tmp"
> ALTER TABLE
> postgis=# \d tmp
> Table "pg_temp_2.tmp"
> Column | Type | Modifiers
> geom | geometry |
> Indexes:
> "unique_geom" UNIQUE, btree (geom)
> postgis=# insert into tmp values ('LINESTRING(0 0, 1 1)'::geometry);
> INSERT 0 1
> postgis=# insert into tmp values ('LINESTRING(1 1, 0 0)'::geometry);
> ERROR: duplicate key value violates unique constraint "unique_geom"
> Sindile ,
> An alternative way would be to load the data into PostGIS using the shape
> dump as usual. If you have a distinct key (other than the gid which is
> added by shp2pgsql) on your features, you could create a new table,
> selecting from your postgis table using DISTINCT ON
> (my_distinct_feature_key).
> http://www.postgresql.org/docs/8.3/static/sql-select.html#SQL-DISTINCT
> Or, you could try:
> CREATE TABLE new_distinct_table AS
> SELECT att1, att2, geom::geometry
> FROM (
> SELECT DISTINCT att1, att2, encode(geom, 'hex') as geom
> FROM my_polygon_table ) AS foo
> Or, use Jean's method, but instead of the unique constraint on the geom,
> use a unique functional index using the geometry's hex string.
> postgis=# CREATE UNIQUE INDEX tmp_geom_unq ON tmp (encode(geom, 'hex'));
> CREATE INDEX
> INSERT 0 1
> INSERT 0 1
> ERROR: duplicate key value violates unique constraint "tmp_geom_unq"
> postgis=# \d tmp
> geom | geometry |
> Indexes:
> "tmp_geom_unq" UNIQUE, btree (encode(geom::bytea, 'hex'::text))
> Remember though, that this is *not* a spatial geometry index, just a unique
> index on the hex string.
> Hope that helps,
> Cheers,
> Kevin
> Jean David TECHER wrote:
>> Example:
>> dbname = routing_db
>> table =wr
>> 1. Load only the table structure not the datas
>> use -p option taken from shp2pgsql
>> shp2pgsql -p wr.shp wr|psql routing_db
>> 2. Add a constraint on the_geom column
>> psql routing_db
>> ALTER TABLE wr ADD CONSTRAINT check_unique_the_geom unique(the_geom);
>> 3. Load your datas without 'BEGIN' and 'END'
>> * Here use the -a option taken from shp2pgsql
>> * use -I for index creation
>> The idea is to use the INSERT command in order to rollbacking if the
>> current feature is already in the table
>> N.B: don't use -D option!
>> shp2pgsql -aI wr.shp wr|grep -v ^BEGIN|grep -v ^END|psql routing_db
>> Quoting Intengu Technologies <sindile.bidla at gmail.com>:
>> I have a polygon shapefile that has duplicate features which I want to
>>> load
>>> into Postgis. How can I ensure that each feature has only one record.
>>> Sindile Bidla
>> Jean David TECHER
>> www.davidgis.fr
>> 06 60 46 85 05
>> 04 99 77 16 87
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Sindile Bidla
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081114/e90208ce/attachment.html>
