[postgis-users] PostGIS 1.3.4 RC3 released
Kevin Neufeld
kneufeld at refractions.net
Fri Nov 14 08:50:07 PST 2008
Ok, so I'm going to chalk it up to a server misconfiguration ... it's an old setup that really needs an overhaul. I get
the same problem using 1.3.3 and I can't reproduce the problem on other servers I performed the installation on.
Nevermind then :)
-- Kevin
Mark Cave-Ayland wrote:
> Kevin Neufeld wrote:
>> Hmmm. No, rerunning autogen didn't solve it. I thought maybe it was
>> a Fedora Core 3 issue, but if it works on the rackmount (which is also
>> FC3), then I don't know. My server setup must be amiss.
>> -- Kevin
> AFAIK the only part of the build system that has changed in RC3 is the
> introduction of "sed" within Makefile.config rather than "cut", and this
> should only affect the extraction of the PostgreSQL version. I think a
> good test is whether 1.3.3 suffers from the same problem on the same
> server.
> ATB,
> Mark.
