[postgis-users] Postgre 8.3.5 & PostGIS SVN 2008-11-13 Updates
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Nov 17 03:45:24 PST 2008
Balkan Uraz wrote:
> Dear All;
> We have been informed that Postgre 8.3.5 Update is critical for
> especially GIST indexes. Therefore we decided to upgrade both Postgre &
> PostGIS.
> We have backed up our system:
>     * Postgre 8.3.3
>     * PostGIS 2008-10-08 SVN
>     * PROJ.4 SVN
>     * GEOS 3.0.0
> We have then, upgraded to 8.3.5 Update for Postgre and 2008-11-13 SVN
> for PostGIS. However, we were not successful to restore our data back in
> some tables. The error was:
> ERROR:  geometry requires more points
>   HINT:  "...000100000003000000E71A66683C954F40018926" <-- parse error
> at position 74 within geometry
>   CONTEXT:  COPY dunyayerlesimalanlari, line 12024, column the_geom:
> "0106000020E61000000100000001030000000100000003000000E71A66683C954F4001892650C4184B40BF45274BAD934F40..."
>   STATEMENT:  COPY dunyayerlesimalanlari (gid, name, featype, the_geom)
> FROM stdin;
> We couldn't find a way, therefore we reverted all our system back to
> 8.3.3 and PostGIS 2008-10-08 SVN .
> Do you have any ideas on the error? How could we resolve that error?
> Also, not specific for this error; is there any predefined procedures
> for updating the Postgre & PostGIS instances?
> Thanks for your help,
> Regards,
> Balkan Uraz.
Hi Balkan,
It looks as if you are using SVN trunk. SVN trunk has already branched
for the 1.4 series and is undergoing a lot of new development -  I'd
avoid it for any production use unless you really know what you're doing.
In terms of the upgrade, you're probably being hit a change in parser
rules (and it's likely these will change again before 1.4 final). So in
other words, leave PostGIS as it is and for the moment just upgrade
PostgreSQL to 8.3.5 and you should be fine.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
