[postgis-users] Ellipses and WGS84
Bruce Rindahl rindahl at lrcwe.com
Mon Nov 17 15:04:09 PST 2008
The example creates an ellipse directly in a projected coordinate
space.  What you need is the difference between latitude and longitude
of 1 meter at the location you want.  Your code should be:
translate(rotate(scale(buffer(GeomFromText('Point(0.0 0.0)', 4326),
r),a,b),alpha),cx,cy)
Where r is the radius in decimal degrees of 1 meter at the equator, b =1
(the 1 meter distance does not change in the N/S direction), alpha is 0
since you will not rotate the ellipse, and cx and cy are you final
lat/long locations.  The a parameter is tricky.  You need to know how
much larger 1 degree of longitude is than 1 degree of latitude is at
cx,cy.  You might try:
 distance_sphere(GeomFromText('Point(cx cy)',
4326),GeomFromText('Point(cx+0.01 cy)', 4326),) /
distance_sphere(GeomFromText('Point(cx cy)', 4326)
,GeomFromText('Point(cx cy+0.01)', 4326))
for the a parameter.
Bruce Rindahl
 David W Talmage - CONTRACTOR wrote:
> Would someone please explain the units in this snippet modeled after
> the exampled offered in
> http://postgis.refractions.net/pipermail/postgis-users/2007-March/014971.html
> What are the units of r, a, and b?  I think they are radians.
> My intention is to create a 1-meter radius circle at the Equator,
> morph  it into an ellipse and then move the ellipse to an area of
> interest on the globe to select the things that are in that area.  All
> of my things are stored with coordinates in WGS84.
> I know the values of a and b in meters.  I have a function that
> computes the number of meters per degree on an ellipsoid at any
> latitude, so I can convert a and b to radians.
> I'm pretty sure that cx and cy are the longitude and latitude,
> respectively, in degrees of the center of the ellipse.
> alpha is in radians.
> I've looked all over for an answer to this question and either I can't
> find it or don't understand what I've found. :-(
> postgis-users mailing list
