[postgis-users] PostGIS 1.3.4 RC3 released
Obe, Regina robe.dnd at cityofboston.gov
Wed Nov 19 04:31:06 PST 2008
Mark,
My general opinion about this.  No its not worth the effort unless it
takes you 5 minutes and won't break anything and doesn't require further
maintenance :).
I figure most people upgrading are probably going to upgrade GEOS.   I
mean you expect all functions to be available in your install and if
they happen to be running a geos that old, I question whether they would
be running the new GCC.
Also its annoying to have to say things like hmm by the way you can't
use ST_SimplifyPreserveTopology because you don't have GEOS 3.0+.  Too
much minutia to remember.
Does the old gcc work fine with old 2....?  If so then scrap fixing it
for new installs -- you want to stick with old technology stick with old
technology across the board period.  If it doesn't then hmm - I would
say lets just say to use 1.3.4 you need to have Geos 3.0.3 or above
installed.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, November 19, 2008 7:15 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS 1.3.4 RC3 released
Obe, Regina wrote:
> Mark,
> Does this count toward your goal or were you looking more for 8.1?
> I installed a fresh PostgreSQL 8.3.5, Geos 3.0.3 RC1, PostGIS 1.3.4SVN
> on a Red Hat Enterprise Linux 4 and it passed all regression tests and
I
> was able to reload my data back.  Hmm on hindsight, I guess I should
> have also tested on the old 8.2 install that was on that box before I
> blew it away, but I was short on time.
> Thanks,
> Regina
Yep that looks fine. The hardest one for me to test at the moment is
GEOS 2.2 since the 2.2 branch doesn't have any of the gcc-4.3 fixes :(
I think I can hack up something based upon the patches in SVN trunk, but
it would be fairly unmaintainable unless they get added to SVN. I wonder
   if it's worth putting out a 2.2.4 release containing just compilation
fixes?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
