[postgis-users] fabs() testing for y-coordinates in lwgeom_svg.c
Klaus Förster
klaus.foerster at uibk.ac.at
Thu Nov 20 02:58:24 PST 2008
yes Mark, I know that the axis is reversed, but I don't get the point
why the if clause is needed: fabs(pt->y) always returns a positive value
or 0 and multiplying 0 with -1 doesn't do any harm. So why not use
sprintf(y, "%.*f", precision, pt->y * -1) and skip the test?
Klaus
Mark Cave-Ayland wrote:
> Klaus Förster wrote:
>> I've just checked the source of lwgeom_svg.c in postgis-1.3.4rc3 and
>> wonder what the fabs() testing in lines 243, 262, 303, 324 and 348 is
>> for. Why is it needed?
>> e.g. line 243:
>> sprintf(y, "%.*f", precision, fabs(pt->y) > 0 ? (pt->y * -1) : pt->y);
>> thanks for any hints,
>> Klaus
> Hi Klaus,
> The trick is the use of the ? operator, and so the above logic reads:
> if fabs(pt->y) > 0 then value = (pt->y * -1), otherwise value = pt->y
> In other words, it inverts the Y-axis - presumably because SVG has a
> top-left origin point as opposed to a bottom-left origin point used by
> the majority of coordinate systems.
> HTH,
> Mark.
Klaus Förster
Institut für Geographie
Universität Innsbruck
A-6020 Innsbruck, Innrain 52
Tel.: +43 (0)512 507 5434
