[postgis-users] ST_AsKML changes in 1.3.3
Obe, Regina robe.dnd at cityofboston.gov
Thu Nov 20 04:47:28 PST 2008
Yah its worth a note.  Guess that should be done for ST_Transform too.
Any other functions require Proj?
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, November 19, 2008 11:12 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ST_AsKML changes in 1.3.3
Dylan Beaudette wrote:
> Thanks for the tips Mark. The funny thing about this specific problem
> is that it occurred with a fresh install from the PostGIS website. I
> was only able to 'discover' _STAsKML() but grepping through
> lwpostgis.sql
> Ideas?
> Dylan
Aha. A quick look at lwpostgis.sql.in shows that ST_AsKML() requires
PROJ.4 in order to run. So it sounds as if configure didn't find it for
some reason, either because it wasn't installed or your --with-proj
argument was wrong.
I think the minor bug here though is that _ST_AsKML() isn't included as
part of the #ifdef section which is why only this function is visible.
I'll go and fix this in 1.3 branch (trunk requires PROJ.4) - I wonder if
it's worth a note in the 1.3 documentation that ST_AsKML() requires
PROJ.4 support - Regina?
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
