[postgis-users] PostGIS 1.3.4 RC3 released
Tim Bowden
tim.bowden at westnet.com.au
Thu Nov 20 07:42:27 PST 2008
On Thu, 2008-11-20 at 19:38 +0900, Tim Bowden wrote:
> On Mon, 2008-11-17 at 20:53 +0000, Mark Cave-Ayland wrote:
> > For the record, PostgreSQL 8.3 with PostGIS 1.3.4rc3 compiles and passes
> > all regression tests on MingW/Win32. Note we're still missing the
> > results for the following combinations:
> > PostgreSQL 8.1+ - GEOS 2.2.3 - Linux
> > PostgreSQL 8.1+ - GEOS 3.0.3 - Linux
> > PostgreSQL 8.1+ - GEOS 3.1 - Linux
> > Remember: the sooner we pass the tests, the sooner we can release 1.3.4 :)
Debian etch, AMD64 dual core
gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
postgresql 8.1.15
postgis 1.3.4rc3
geos 2.2.3, 3.0.3 & 3.1 all make and install fine. Tested all with
importing a shp file using shp2psql no probs.
If it makes any difference I can try again with a 32bit linux (either
etch or ubuntu 7.10) but it will have to wait a day or two if so.
Regards,
Tim Bowden
> I'll test these tonight on debian etch unless anyone else is already
> doing it.
> Regards,
> Tim Bowden
> > ATB,
> > Mark.
Experience is that marvelous thing that enables you recognize a mistake
when you make it again.
