[postgis-users] PostGIS 1.3.4 RC3 released
Paul Ramsey pramsey at cleverelephant.ca
Mon Nov 24 10:14:25 PST 2008
I have fixed the regression failure on pre-8.2 pgsql, which was
unrelated to PostGIS, just the use of SELECT FROM VALUES that I used
in the regress_ogc_prep.sql file, and was not supported in earlier
versions.
P.
On Mon, Nov 24, 2008 at 3:23 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Peter Hopfgartner wrote:
>> On current CentOS 5, with PostgreSQL 8.1.11, and current EPEL repository
>> with GEOS (geos-2.2.3-3.el5.rpm) everything runs fine:
>> Run tests: 38
>> Feiled: 0
>> Regards,
>> Peter
> Thanks Peter. So it seems as if it's a GEOS 3.1 (SVN trunk) related issue?
> Over to you, Paul...
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
