[postgis-users] 1.3.4rc3 regression failure
Paul Ramsey pramsey at cleverelephant.ca
Mon Nov 24 22:27:23 PST 2008
Excellent timing, I just pushed to release.
An issue for 1.3.5 :)
P
On Mon, Nov 24, 2008 at 9:09 PM, Stephen Davies <sdc at sdc.com.au> wrote:
> I have just built 1.3.4rc3 and run the regression tests.
> Test 17 failed with:
>  PostgreSQL 8.3.5 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.1
> (Mandrake Linux 9.2 3.3.1-2mdk)
>  Postgis 1.3.4rc3 - 2008-11-25 03:24:13
>   GEOS: 3.0.0rc4-CAPI-1.3.3
>   PROJ: Rel. 4.5.0, 22 Oct 2006
> Running tests
>  regress_lrs. failed (diff expected obtained: /var/lib/pgsql/tmp/test_17_diff)
> Diff file has:
> 17c17
> < LINEZM_6|POINT(9.5 0.5 0.5 2)
>> LINEZM_6|LINESTRING(9.5 0.5 0.5 2,9.5 0.5 0.5 2)
> 60c60
> All else seems AOK.
> Cheers,
> Stephen Davies
> Stephen Davies Consulting P/L                             Voice: 08-8177 1595
> Adelaide, South Australia.                                Fax  : 08-8177 0133
> Computing & Network solutions.                            Mobile:040 304 0583
>                                          VoIP:sip:1132210 at sip1.bbpglobal.com
> postgis-users mailing list
