[postgis-users] help with a query
Pedro Doria Meunier
pdoria at netmadeira.com
Tue Nov 25 06:52:18 PST 2008
Hi Fred,
Thanks for taking an interest :)
Well ... I'd already done it for the one-way streets.
There are 2 scenarios here:
- vehicle routes
- pedestrian routes
So when I'm trying to calculate a route for a vehicle I don't want the
algorithm to include road_type=22.
Whenever I decide to calculate a pedestrian route it must return all of
the possible segments.
The wrappers themselves don't allow you to do that ...
BR,
Pedro Doria Meunier
Fred Lehodey wrote:
> Hi Pedro,
> you are calculating the route with all roads and only after you are
> filtering with the WHERE clause.
> IMO, better is to create a field with high costs (Ex:10000) to roads
> when road_type=22 and length for road_type != 22.
> After that, you can run the function shortest_path() using your new
> cost field.
> Fred.
> On Tue, Nov 25, 2008 at 2:16 AM, Pedro Doria Meunier
> <pdoria at netmadeira.com <mailto:pdoria at netmadeira.com>> wrote:
> Hi guys :) -- a *special* wink to David Techer ;-)
> I'm having a bit of trouble figuring out what can I do with the
> wrapper functions of pgRouting... (blush)
> The thing is:
> I have everything perfectly in place, pgRouting working as it's
> supposed to, but!
> I have a dataset that describes the road type. I want to filter
> the results provided by pgRouting in a way that it *doesn't*
> return return pedestrian segments (btw: road_type=22).
> So, as to the query itself (basic) 1st try:
> SELECT gid, AsBinary(the_geom) AS the_geom
> FROM dijkstra_sp_directed('pt_madeira_roads', 11780, 424, true,
> true);
> Works like a charm except that it returns pedestrian segments (of
> course).
> 2nd try:
> SELECT rt.gid, AsText(rt.the_geom) AS wkt,
> length(rt.the_geom) AS length, roads.gid
> FROM my_roads as roads,
> (SELECT gid, the_geom
> 'my_roads',
> 11780,
> 424,
> true,true)
> ) as rt
> WHERE roads.road_type<>22 and roads.gid=rt.gid;
> Leaves me with *holes* in the route.
> All of this is, of course, a consequence of my own stupidity and
> late hours but I'd surely appreciate if some brave soul could look
> into it. ;-)
> Already thankful in advance,
> Pedro Doria Meunier.
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
