[postgis-users] Get concave hull from an array of longitude inlatitude points
Rob Tester
robtester at gmail.com
Tue Nov 25 12:36:57 PST 2008
I think you were hit by the blind stick.
The license is LGPL and QPL. They will sell you a commercial license if you
require one.
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Alpha_shapes_2/Chapter_m
ain.html
This chapter is all about alpha shapes (which can be concave or convex).
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tim
Bowden
Sent: Tuesday, November 25, 2008 1:25 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Get concave hull from an array of longitude
inlatitude points
On Tue, 2008-11-25 at 06:22 -0700, Rob Tester wrote:
> CGAL has an open source implementation of the algorithm. (Along with some
> other really neat things like vonoroi).
There is certainly some quite interesting (mostly non free) stuff there.
I can see an lgpl convex hull module but not concave unless I've been
hit with the blind stick.
Regards,
Tim
Experience is that marvelous thing that enables you recognize a mistake
when you make it again.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
