[postgis-users] 1.3.4rc3 regression failure
Stephen Davies sdc at sdc.com.au
Tue Nov 25 17:51:59 PST 2008
The site in question did not have 1.3.3. It was still at 1.3.2.
I reran the tests with 1.3.2 and there were no failures so I built 1.3.3 and
tried again.
This gave no errors.
I cannot reproduce the issue on their test box.
It should be possible to arrange access to the box. Contact me off-list to
discuss details.
Cheers,
Stephen
On Tuesday 25 November 2008 21:12:33 Mark Cave-Ayland wrote:
> Stephen Davies wrote:
> > I have just built 1.3.4rc3 and run the regression tests.
> > Test 17 failed with:
> >  PostgreSQL 8.3.5 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.1
> > (Mandrake Linux 9.2 3.3.1-2mdk)
> >  Postgis 1.3.4rc3 - 2008-11-25 03:24:13
> >    GEOS: 3.0.0rc4-CAPI-1.3.3
> >    PROJ: Rel. 4.5.0, 22 Oct 2006
> > Running tests
> >  regress_lrs. failed (diff expected obtained:
> > /var/lib/pgsql/tmp/test_17_diff)
> > Diff file has:
> > 17c17
> > < LINEZM_6|POINT(9.5 0.5 0.5 2)
> >> LINEZM_6|LINESTRING(9.5 0.5 0.5 2,9.5 0.5 0.5 2)
> > 60c60
> > All else seems AOK.
> > Cheers,
> > Stephen Davies
> One more quick question: does "make check" on 1.3.3 pass without any
> errors?
> ATB,
> Mark.
Stephen Davies Consulting P/L                             Voice: 08-8177 1595
Adelaide, South Australia.                                Fax  : 08-8177 0133
Computing & Network solutions.                            Mobile:040 304 0583
                                          VoIP:sip:1132210 at sip1.bbpglobal.com
