[postgis-users] Integer (PostGIS) fields become real in QGIS!
Vito Meuli v.meuli at tecnologieavanzate.it
Wed Nov 26 07:01:54 PST 2008
Hi!
I'm using shapefile exported from PostGIS using pgsql2shp.
But QGIS takes the integer fields as they were real!
I've tryed different version of PostGIS, and something changed: integer=int4
become a 16 digit precision in a shapefile exported using PostGIS 1.0.6, and
a 11 digit precision using PostGIS 1.3.3...
What a pity, it seems that an integer remains an integer if it is 10 digit
precision!
It's not better if I use smallint instead of int4: pgsql2shp acts the same
way.
If I export shapefiles from PostGIS using QGIS directly, all goes well and the
int4 remain integer.
Is there some other way to extract shapefile using a shell (Linux) script and
letting them have integer fields of 10 digit precision?
Any help would be appreciated.
Bye
Vito
Ing. Vito Meuli
Tecnologie Avanzate S.r.l.
via B. Croce, 49
70015 Noci (BA)
tel. +39 080 4979652
fax  +39 080 4979263
email: v.meuli at tecnologieavanzate.it
http://www.tecnologieavanzate.it
