[postgis-users] Arc catalog (Arc GIS) import
Randall, Eric
ERandall at eriecountygov.org
Wed Nov 26 08:29:47 PST 2008
Bruce,
Not much. I probably should have said "less possible". I'm not very ArcObjects experienced so
while I'm sure anything is possible, for me the first reliable solution tends to get used and
the better solutions exist in the "time permitting" continuum.
-Eric
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Clay,
Bruce
Sent: Wednesday, November 26, 2008 10:26 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Arc catalog (Arc GIS) import
Eric:
You said "not possible with ArcObjects". Just out of curiosity have
you tried a mixture of ArcObjects and GDAL/OGR? I have that on my list
of things to do but I don't want to go down that path if it has been
tried and doesn't work.
Bruce
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Randall, Eric
Sent: Wednesday, November 26, 2008 9:55 AM
Hi John,
You could create a custom menu/toolbar in ArcMap or ArcCatalogue and
then using VBA:
1. use the "Shell" command to pass pgsql2shp (or ogr2ogr) command and
it's arguments to the database (or .bat doing the same).
2. add the shape(s) to your project (or "Refresh" if already there).
It's not very beautiful but I use this method to pass arguments from
ArcMap to PostGIS functions to do their work and then
write updated shapes back out. A pretty "loose coupling" to PostGIS
admittedly. Two reasons I do this are:
1. To do things that are easier, less agravating, or not possible (for
me anyway) with Modelbuilder,Toolbox,ArcObjects.
2. If you need to showcase some PostGIS functionality and people don't
see an ESRI frontend, they tend to look at you like you have three
heads.
I look forward to using ZigGIS. That will eliminate the shape writing
stuff. That's still a month away though (new year, new budget).
-Eric
Eric Randall
GIS DB Admin/Analyst
County of Erie
140 W 6th St
Room 119
Erie, PA 16501
ph. 814-451-6063
fx. 814-451-7000
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of John
Abraham
Sent: Tuesday, November 25, 2008 7:00 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Arc catalog (Arc GIS) import
A colleague told me that ArcGIS could import postgis layers directly,
without using Ziggis. I've been googling around and playing with ArcMAP
and ArcCatalog trying to figure it out, but no luck so far.
I know I could use pgsql2shp. And I know I could use Ziggis commercial
(2.x) or Ziggis open source (1.x). But for our needs a direct import
menu item within ArcMAP or ArcCatalog would be best, as they would like
to frequently view snapshots of the data.
Any other suggestions also appreciated, thanks.
John Abraham
jabraham at ucalgary.ca
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
