[postgis-users] Union of MultiPolygons
Paul Ramsey pramsey at cleverelephant.ca
Wed Nov 26 11:10:40 PST 2008
Probably your multipolygons are merging into a proper polygon.
INSERT INTO county (polygon_nm, the_geom) VALUES ('X',
st_multi(st_union((select the_geom from county where polygon_nm='LAKE'), (select
the_geom from county where polygon_nm='COOK'))))
Yes, st_union can operate as an aggregate.
CREATE TABLE states_from_couties AS
select st_multi(st_union(the_geom)) from county
group by state;
P.
On Wed, Nov 26, 2008 at 11:02 AM, C. Y. W. <cyw at dls.net> wrote:
> Hi All,
> I have  a table with counties as Multipolygons. I need to define a new
> multipolygon with some of these counties.
> I tried to run this :
> And I got constraint "enforce_geotype_the_geom" violations.
> I guess st_union returns something that's not a Multipolygon.
> What should I do?
> Anyway to merge more than 2 Multipolygons at a time?
> Thanks,
> cyw
> postgis-users mailing list
