[postgis-users] Help with query
Mark
mark.balman at gmail.com
Thu Nov 27 11:01:22 PST 2008
Hi All
I am currently trying to create a query to pass through to mapserver but
am having a problem. Here is my scenario:
Two tables in postgresql
A quarter degree grid with 273600 records (spatial geometry) with GiST index on
the geometry and a btree index on FID
A species table with 10 million records (btree index on FID1) contains species ids with related
grid cell ids (essentially an intersect)
In mapserver I have defined the layer thus
LAYER
CONNECTIONTYPE postgis
NAME "SpcDensity"
CONNECTION "user="" password="" dbname="" host=localhost"
DATA "the_geom FROM (select spcdensity.fid_1, spcdensity.the_geom AS
the_geom, gid AS gid, spcgrid.spcid
from spcdensity, spcgrid
where spcdensity.fid_1 = spcgrid.fid) as myquery using SRID=4326 using
unique gid"
STATUS OFF
TYPE POLYGON
TEMPLATE "templates/spc_header.html"
CLASS
NAME "density"
OUTLINECOLOR 128 128 128
END
JOIN
NAME "species"
CONNECTION "host=localhost port=5432 user="" password="" dbname="""
CONNECTIONTYPE ogr
TABLE "spcgrid"
FROM "fid_1"
TO "fid"
TYPE ONE-TO-ONE
END
END
When I run this it works fine, click in a quarter degree grid cell and
it returns a species ID using the one-to-one join but I need to get it
to return the many species ids. Changing the join type to ONE-TO-MANY
results in the error:
loadJoin(): Premature End-of-File. One-to-many joins must define template and name properties
If anyone has any suggestions as to how I can get this to work I would
be most grateful.
Thanks in advance
Mark
