[postgis-users] "summing" (polygon, float) pairs
Reid Priedhorsky reid at umn.edu
Wed Oct 1 15:35:25 PDT 2008
Dear all,
I have a set of polygons. Associated with each polygon is a number; call
it score. Each polygon can intersect with zero or more other polygons.
What I would like to compute is a set of non-intersecting polygons with
summed scores -- each of these polygons would be a set of points where
the sum of all the original polygons' scores covered by the result
polygon are equal.
Here's an example in one dimension:
Input:
----3------
      ----1----
         ----4----
                     ----2----
Output:
--3--
      -4-
         -8-
            -5-
               -4-
                     ----2-----
It is OK if two adjacent result polygons have equal sums.
Can this be done in PostGIS?
Reid
p.s. thanks for the help on my question a few days ago! I felt a tad
foolish after learning it was just a missing isvalid() constraint. I
thought I had one but didn't look carefully enough.
