[postgis-users] "summing" (polygon, float) pairs
Obe, Regina
robe.dnd at cityofboston.gov
Thu Oct 2 07:51:23 PDT 2008
If the below conditions are true, then I would say you can do this in
PostGIS.
A solution that comes to mind is this
SELECT Sum(score) as totscore, ST_Union(the_geom) as newgeom
FROM poly
GROUP BY CAST(random()*10000 As int)
HAVING All_Disjoint(the_geom)
Set the 10000 so some function of the size of your set. You always want
it to be lower than the number of polygons you have. The larger the
number the fewer polygons you would expect per match.
All_Disjoint is a yet to be defined aggregate function you will need to
create yourself that checks each
incoming geometry against the previous set and returns true if it is
disjoint (not intersecting) any of the previous.
Unfortunately the above will not use indexes.
Aggregates are pretty easy to create in PostgreSQL so I'll leave that as
an exercise for you to figure out. The answers to the above will
probably give different answers each time since it does a random walk.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: Thursday, October 02, 2008 10:28 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] "summing" (polygon, float) pairs
Reid,
I assume
1) You don't care if polygons are reused to form your new sets
2) You don't care how many polygons are in each set.
3) You also are not looking for all possible permutations - just a
random set of answers that solve your equation?
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Reid
Priedhorsky
Sent: Wednesday, October 01, 2008 6:35 PM
Subject: [postgis-users] "summing" (polygon, float) pairs
Dear all,
I have a set of polygons. Associated with each polygon is a number; call
it score. Each polygon can intersect with zero or more other polygons.
What I would like to compute is a set of non-intersecting polygons with
summed scores -- each of these polygons would be a set of points where
the sum of all the original polygons' scores covered by the result
polygon are equal.
Here's an example in one dimension:
Input:
----3------
----1----
----4----
----2----
Output:
--3--
-4-
-8-
-5-
-4-
----2-----
It is OK if two adjacent result polygons have equal sums.
Can this be done in PostGIS?
Reid
p.s. thanks for the help on my question a few days ago! I felt a tad
foolish after learning it was just a missing isvalid() constraint. I
thought I had one but didn't look carefully enough.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
