[postgis-users] "summing" (polygon, float) pairs
Obe, Regina
robe.dnd at cityofboston.gov
Thu Oct 2 09:08:50 PDT 2008
Martin,
Your interpretation was much more useful than my interpretation. I was
wandering why Reid would want to do such a silly thing. Thought maybe he
was bored.
I guess I read it wrong. Are never mind then what I said.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Martin Davis
Sent: Thursday, October 02, 2008 12:03 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] "summing" (polygon, float) pairs
I read the original request as asking how to create a non-overlapping
coverage from a set of overlapping polygons, and attribute each face of
the coverage with the sum of its parent polygons' scores. I think this
is different to your solution.
AFAIK the best way to create a non-overlapping coverage from a set of
overlapping polygons is to extract the linework (boundaries) from the
polygons, node it together (by unioning all the lines) and then
re-polygonize. A point-in-polygon for each new face against the
original set can be used to determine the parents, and then the summing
is easy.
Obe, Regina wrote:
> If the below conditions are true, then I would say you can do this in
> PostGIS.
> A solution that comes to mind is this
> SELECT Sum(score) as totscore, ST_Union(the_geom) as newgeom
> FROM poly
> GROUP BY CAST(random()*10000 As int)
> HAVING All_Disjoint(the_geom)
> Set the 10000 so some function of the size of your set. You always
want
> it to be lower than the number of polygons you have. The larger the
> number the fewer polygons you would expect per match.
> All_Disjoint is a yet to be defined aggregate function you will need
to
> create yourself that checks each
> incoming geometry against the previous set and returns true if it is
> disjoint (not intersecting) any of the previous.
> Unfortunately the above will not use indexes.
> Aggregates are pretty easy to create in PostgreSQL so I'll leave that
as
> an exercise for you to figure out. The answers to the above will
> probably give different answers each time since it does a random walk.
> Hope that helps,
> Regina
Obe,
> Regina
> Sent: Thursday, October 02, 2008 10:28 AM
> Subject: RE: [postgis-users] "summing" (polygon, float) pairs
> Reid,
> I assume
> 1) You don't care if polygons are reused to form your new sets
> 2) You don't care how many polygons are in each set.
> 3) You also are not looking for all possible permutations - just a
> random set of answers that solve your equation?
Reid
> Priedhorsky
> Sent: Wednesday, October 01, 2008 6:35 PM
> Subject: [postgis-users] "summing" (polygon, float) pairs
> Dear all,
> I have a set of polygons. Associated with each polygon is a number;
call
> it score. Each polygon can intersect with zero or more other polygons.
> What I would like to compute is a set of non-intersecting polygons
with
> summed scores -- each of these polygons would be a set of points where
> the sum of all the original polygons' scores covered by the result
> polygon are equal.
> Here's an example in one dimension:
> Input:
> ----3------
> ----1----
> ----4----
> ----2----
> Output:
> --3--
> -4-
> -8-
> -5-
> -4-
> ----2-----
> It is OK if two adjacent result polygons have equal sums.
> Can this be done in PostGIS?
> Reid
> p.s. thanks for the help on my question a few days ago! I felt a tad
> foolish after learning it was just a missing isvalid() constraint. I
> thought I had one but didn't look carefully enough.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
