[postgis-users] Re: Spring/Hibernate/JDBC with PostgreSQL/PostGIS types?
Stefan Keller
sfkeller at gmail.com
Thu Oct 2 10:23:49 PDT 2008
It's hard to believe that we are the first and the only ones (as of now)
to combine Grails/Groovy/Spring/Hibernate and PostGIS - but so it seems to be!
We've now found a solution and will blog about this soon.
Yours, Stefan
2008/9/24 Stefan Keller <sfkeller at gmail.com>:
> I'm stuck in using Grails/Groovy/Spring/Hibernate to access PostgreSQL/PostGIS.
> I'd like to simply sketch a class like this:
> class POI {
> String name
> Geometry java_geom // from com.vividsolutions.jts.geom.Geometry? (POINT)
> ... and then map java_geom to 'the_geom' of type geometry/POINT (in PostgreSQL).
> I found mainly this: In the FOSS4G '07 symposium
> http://www.foss4g2007.org/presentations/view.php?abstract_id=118 (did
> reverse mapping instead of forward). In
> http://www.pascalalma.net/2007/03/04/entering-the-world-of-gis/ (old?)
> and of course HibernateSpatial (doesn't fit to Grails/Groovy/Spring?).
> Does anyone have experience with Spring/Hibernate+PostGIS or
> Grails/Groovy/Spring/Hibernate+PostGIS ?
> -- Stefan
