[postgis-users] Newbie question - Transfer attributes from onefeature to another
Intengu Technologies sindile.bidla at gmail.com
Mon Oct 6 05:08:06 PDT 2008
Regina,
Solution 3 is would work fine, but was hoping for a solution to transfer the
attributes into one field without duplicating the poly.
Thanks for the pointer.
2008/10/6 Obe, Regina <robe.dnd at cityofboston.gov>
>  Sindile,
> If a polygon has one or more point features and you want to transfer the
> attributes from the point feature to the polygon feature, then what do you
> do in cases where there are multiple points in a polygon
> would you
> 1) pick the first one you hit
> 2) Sum up, take the max etc. of each
> 3) Duplicate the poly for each point?
> In all cases, you will want to do an intersect check
> (solution 1)
>  SELECT DISTINCT ON(poly.gid) poly.gid, poly.the_geom, point.somefield1 As
> somefield1, point.somefield2 As somefield2
> FROM
> table1 As poly INNER JOIN table2 As point
> ON ST_Intersects(poly.the_geom, point.the_geom)
> ORDER BY poly.gid, point.gid;
> (solution to 2 would look something like this)
> SELECT poly.gid, poly.the_geom, SUM(point.somefield1) As totsomefield1,
> MAX(point.somefield2) As maxsomefield2
> FROM
> GROUP BY poly.gid, poly.the_geom;
> (solution to 3)
>   SELECT poly.gid, poly.the_geom, point.somefield1 As somefield1,
> FROM
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Intengu
> Technologies
> *Sent:* Monday, October 06, 2008 4:47 AM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] Newbie question - Transfer attributes from
>  I have a polygon (table1) and a point (table2) feature and would want to
> transfer attributes from the point feature to the polygon feature based on
> whether the point feature is completely enclosed by the polygon feature.
> The polygon feature can have one or more point features.
> How do i transfer the attributes.
> Sindile Bidla
> * The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer. *
> * Help make the earth a greener place. If at all possible resist printing
> this email and join us in saving paper. *
> postgis-users mailing list
Sindile Bidla
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081006/260123c8/attachment.html>
