[postgis-users] ST_SPHEROID_LENGTH SLOW
David Vaz
davidvaz at dcc.fc.up.pt
Wed Oct 8 02:03:08 PDT 2008
Mark Cave-Ayland wrote:
> Have you tried a pg_dump/re-initdb/pg_restore cycle on your 8.3
> installation? If the problem turns out to be either corruption or
> table/index bloat then this should immediately resolve it. Also just
> to confirm - where are you getting your debian packages from?
I have tried the pg_dump/re-initdb/pg_restore, and although You were
wright I was suffering from table/index bloat the time results are the same:
EXPLAIN ANALYSE select length_spheroid(geom,'SPHEROID["WGS
84",6378137,298.257223563]') FROM test order by id limit 100;
QUERY
PLAN
Limit (cost=0.00..11.07 rows=100 width=36) (actual
time=219.032..59913.512 rows=100 loops=1)
-> Index Scan using test_pkey on tracker_track (cost=0.00..1439.93
rows=13010 width=36) (actual time=219.029..59913.377 rows=100 loops=1)
Total runtime: 59913.701 ms
(3 rows)
In 8.2 Total runtime was 588.495 ms
They are from the official debian "testing/lenny" repository, the 8.2
version is not available any more, but I can give you the .deb if you
want to try it out. But the 8.3 is the problematic one, and that is main
version on lenny.
Regards
