[postgis-users] Conterra and ESRI 9.3 (part 2)
Obe, Regina robe.dnd at cityofboston.gov
Thu Oct 9 08:10:02 PDT 2008
Carmen,
Are you set on Conterra?  If so what features do you like about
Conterra?
Is the spatial library mostly for desktop use or for server side use?
I take it you don't want to spend the money on an ArcSDE server license?
You might want to take a look at ZigGIS.  I'm not sure if makes sense
for your use case though since its targeted toward the desktop
rather than server-side use.
http://pub.obtusesoft.com/pr.html
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Constantine.Carmen at epamail.epa.gov
Sent: Thursday, October 09, 2008 10:55 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Conterra and ESRI 9.3 (part 2)
I posted a similar question yesterday, I colleague helped me with some
additional important points.........
We are currently developing a PostGIS spatial "library" and would like
ArcGIS 9.3 Desktop products to read and utilize this library through as
simple an interface as possible, ideallying using SLDs or .lyr to
symbolize the layers for the end users.  Using WFS-editor might be
preferable to ESRI's rather thin "Data Interpoperability Extension"
which has no useful UI to speak of.  Conterra does not provide much
info, no screen captures, and no demo.  We're evaluating this approach
in parallel to a PostGIS shared backend with ArcSDE/ArcGIS Server using
PostGIS data types in Postgres.
Any thoughts or ideas would be appreciated. Thanks - Carmen
Carmen Constantine
US EPA Region 3 GIS Team
Vistronix, Inc
On-Site Contractor
215-814-5418
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
