[postgis-users] TRANSFORM failures with some multiploygons - data sample attached
Paul Ramsey pramsey at cleverelephant.ca
Thu Oct 9 20:12:46 PDT 2008
>> It ran without any error. But some of the resulted values in the_geom
>> column became null or empty.
How did you check this?
select gid from thetable where the_geom is null?
select gid from thetabel where npoints(the_geom) =
P
