[postgis-users] PostGIS Transform and Quantum GIS
cyw at dls.net cyw at dls.net
Fri Oct 10 08:17:47 PDT 2008
Thanks, Paul.
1. What do you mean by  GEOMETRY_COLUMNS ? Do you mean the 'geometry'
column?
I did "select srid(the_geom) from city limit 10" on the transformed table,
it retured '26971'.
2.  I tried to display the transformed table with new QuantumGIS project
(new db connect, add, ...). I actually just did upgrade to the newest Dev
version of QuantumGIS. Still the same.
CYW
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, October 10, 2008 9:58 AM
Subject: Re: [postgis-users] PostGIS Transform and Quantum GIS
> Try removing the table from qgis and re-adding it. And don't forget to
> change the SRID value in GEOMETRY_COLUMNS before you do. I think
> you're altering the coordinates underneath QGIS's understanding of
> that they are (it things it has a 4326 table, and boom, you turn it
> into something else).
> P.
> On Fri, Oct 10, 2008 at 7:16 AM,  <cyw at dls.net> wrote:
>> Just wonder if anyone had similar experience.
>> I have a table with multipolygons for cities (in latitude/longitude,
>> srid=4326), I could display it with QuantumGIS.
>> Then I did a transform to a plane coordinate system, and verified the
>> result
>> (astext(the_geom)) and saw  no problem.
>> Then I tried to view it again with QuantumGIS. Though no error message,
>> nothing could be display. After zoom-to-layer, the cursor coordinate
>> values
>> were consitent with the extent of the data in the projected coordinate
>> system.
>> Below are the SQL command I did:
>> ALTER TABLE city DROP CONSTRAINT enforce_srid_the_geom;
>> update city set the_geom=transform(the_geom,26971)  where
>> polygon_id=35665106;
>> alter table city add CONSTRAINT enforce_srid_the_geom CHECK
>> (srid(the_geom)
>> = 26971);
>> Thanks,
>> CYW
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
