[postgis-users] PostGIS Transform and Quantum GIS
cyw at dls.net
cyw at dls.net
Fri Oct 10 08:39:46 PDT 2008
Thanks. That's exactly the problem.
CYW
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, October 10, 2008 10:27 AM
Subject: RE: [postgis-users] PostGIS Transform and Quantum GIS
Geometry_Columns is a table that contains the listing of table geometry
columns.
It gets autofilled when you do AddGeometryColumn to add a geometry
column.
So as Paul said you will need to manually correct the table because
Quantum is probably reading it as a faster way of determining the SRID.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
cyw at dls.net
Sent: Friday, October 10, 2008 11:18 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS Transform and Quantum GIS
Thanks, Paul.
1. What do you mean by GEOMETRY_COLUMNS ? Do you mean the 'geometry'
column?
I did "select srid(the_geom) from city limit 10" on the transformed
table,
it retured '26971'.
2. I tried to display the transformed table with new QuantumGIS project
(new db connect, add, ...). I actually just did upgrade to the newest
Dev
version of QuantumGIS. Still the same.
CYW
Sent: Friday, October 10, 2008 9:58 AM
> Try removing the table from qgis and re-adding it. And don't forget to
> change the SRID value in GEOMETRY_COLUMNS before you do. I think
> you're altering the coordinates underneath QGIS's understanding of
> that they are (it things it has a 4326 table, and boom, you turn it
> into something else).
> P.
> On Fri, Oct 10, 2008 at 7:16 AM, <cyw at dls.net> wrote:
>> Just wonder if anyone had similar experience.
>> I have a table with multipolygons for cities (in latitude/longitude,
>> srid=4326), I could display it with QuantumGIS.
>> Then I did a transform to a plane coordinate system, and verified the
>> result
>> (astext(the_geom)) and saw no problem.
>> Then I tried to view it again with QuantumGIS. Though no error
message,
>> nothing could be display. After zoom-to-layer, the cursor coordinate
>> values
>> were consitent with the extent of the data in the projected
coordinate
>> system.
>> Below are the SQL command I did:
>> ALTER TABLE city DROP CONSTRAINT enforce_srid_the_geom;
>> update city set the_geom=transform(the_geom,26971) where
>> polygon_id=35665106;
>> alter table city add CONSTRAINT enforce_srid_the_geom CHECK
>> (srid(the_geom)
>> = 26971);
>> Thanks,
>> CYW
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
