[postgis-users] Problem with LWGEOM_collect_garray - never returns MultiX from MultiX?
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 10 16:16:34 PDT 2008
OK, I agree, the comment header and the behavior differ... I'm a bit
afraid to change this behavior though... it's a bit long-standing now.
I wonder if doing so would cause and serious problems for people.
P.
On Wed, Feb 6, 2008 at 5:31 AM, Marcus Jenkins <mgwjenkins at gmail.com> wrote:
> Dare I say it, but I think there's a bug in lwgeom_functions_basic.c
> in the LWGEOM_collect_garray function. According to the docs /
> comments, this should return a multiX if all the objects are multiX,
> but the code on line 2112 (and around) appears to stop that happening.
> /* Output type not initialized */
> if ( ! outtype ) {
> /* Input is single, make multi */
> if ( intype < 4 ) outtype = intype+3;
> /* Input is multi, make collection */
> else outtype = COLLECTIONTYPE;
> Or, in pseudo-code, if the input object is a multiX or collection, the
> output will be a GOEMETRYCOLLECTION. Always. This ain't what it says
> in the function header.
> * returned geometry is the simplest possible, based on the types
> * of the collected objects
> * ie. if all are of either X or multiX, then a multiX is returned
> I tried logging the bug on the PHP bug tracker, but I think I need to
> be a different class of user since I'm asked to log in (when I'm
> already logged in) to post a bug report.
> postgis-users mailing list
