[postgis-users] Indices for ST_distance_sphere
Stephen Baillie
steve at alliancesoftware.com.au
Sun Oct 12 16:56:16 PDT 2008
Thanks to some helpful input from this list, I've got PostgreSQL/PostGIS
to find me all the entities within a given distance of an arbitrary
point. However, it takes about 5 seconds to search the database for
this data, which is too long for the application in question. I'm not
overly concerned about that at this point, as it isn't using any indices
in that search, so it can presumably be made much faster. However, I'm
not sure how best to index this.
I can work out how to get PostgreSQL to build an index based on distance
from a constant point, but not how to extend that to an index based on
distance from an arbitrary point. Is there some clever way in PostGIS
to do this kind of distance based index?
If that's not possible, the next best approximation seems to be putting
indices on my lat and long fields and restricting my search to the
bounding box of my circle of interest, then using ST_distance_sphere to
do the more precise check for each entity inside the bounding box.
What have others done when faced with this choice?
Thanks,
Steve.
Stephen Baillie
Developer
Alliance Software
1/234 Whitehorse Road
Nunawading, VIC 3131
Australia
Ph: 03 9877 9921
Fax: 03 9894 2106
