[postgis-users] GeometryCollection after ST_Centroid(ST_Dump)
Obe, Regina
robe.dnd at cityofboston.gov
Tue Oct 14 05:24:02 PDT 2008
Birgit,
So you are saying ST_Centroid sometimes returns geometry collections.
Hmm I don't see how that is possible unless there is bug somewhere.
Can you provide an example of that. Regarding the below query - it
would be a bit easier to follow if you did a subselect first.
Something like
SELECT
abdump.gid,
abdump.objart_07,
abdump.cat_07,
ST_X(ST_Centroid(abdump.newgeom)) As x_centroid,
ST_Y(ST_Centroid(abdump.newgeom)) As y_centroid
ST_Area(ST_Centroid(abdump.newgeom)) As area,
ST_Perimeter(ST_Centroid(abdump.newgeom)) as perimeter
FROM (SELECT (ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom As newgeom, a.gid, a.objart_07, a.cat_07, a.the_geom
as a_the_geom, b.the_geom as b_the_geom
FROM
bfn.test_mv_dlm07 a, bfn.test_mv_dlm07 b
WHERE ST_Overlaps(a.the_geom,b.the_geom)=true AND
Intersects(a.the_geom,b.the_geom)=true
) As abdump
GROUP BY ST_X(ST_Centroid(abdump.newgeom)),
ST_Y(ST_Centroid(abdump.newgeom)), ST_Area(ST_Centroid(abdump.newgeom)),
ST_Perimeter(ST_Centroid(abdump.newgeom)), abdump.gid, abdump.objart_07,
abdump.cat_07, a_the_geom, b_the_geom
ORDER BY x_centroid asc, y_centroid asc, area asc, perimeter asc, a.gid
asc;
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Birgit Laggner
Sent: Tuesday, October 14, 2008 6:56 AM
To: PostGIS Users Discussion
Subject: [postgis-users] GeometryCollection after ST_Centroid(ST_Dump)
Dear list,
I have a SELECT statement in which I try to group by the polygons
resulting from a self intersection. After I realized that I can't group
by the_geom because this would group polygons which are only similar but
not equal, I decided to group by the area, the perimeter and the x- and
y-coordinates of the centroid of every polygon. The SELECT statement I
wrote, worked so far for some test datasets and showed seemingly
reasonable results. But for at least one of my datasets, the statement
does not work, because the ST_Centroid produces some GeometryCollections
instead of POINTS. What could cause that problem and how can I solve
it???
This is my statement:
SELECT
a.gid,
a.objart_07,
a.cat_07,
ST_X(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)) as x_centroid,
ST_Y(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)) as y_centroid,
ST_Area((ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom) as
area,
ST_Perimeter((ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom)
as perimeter,
(ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom as the_geom
FROM bfn.test_mv_dlm07 a, bfn.test_mv_dlm07 b
GROUP BY ST_X(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)),
b.the_geom))).geom)), ST_Area((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom), ST_Perimeter((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom), a.gid, a.objart_07, a.cat_07, a.the_geom,
b.the_geom
asc;
The ST_Dump results in POLYGONs, LINESTRINGs and POINTs.
Thank you for any help!
Regards,
Birgit.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
