[postgis-users] 1.3.4SVN Testers Wanted
Havard Tveite
havard.tveite at umb.no
Tue Oct 14 05:35:51 PDT 2008
You requested platform testing for Solaris.
I tried the current svn snapshot (postgis-1.3.svn) yesterday.
configure and make went OK on my Solaris 2.7 (SunOS 5.7) with
GCC 3.3.2, pg 8.1.5, geos 3.0.0 and proj 4.5.
Here is the output of make check:
make -C regress test
make[1]: Entering directory
`/data3/usr/local/src/postgresql/postgresql-8.1.5/contrib/postgis-1.3.svn/regress'
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_9996
PostgreSQL 8.1.5 on sparc-sun-solaris2.7, compiled by GCC gcc (GCC) 3.3.2
Postgis 1.3.4SVN - 2008-10-13 10:54:04
GEOS: 3.0.0-CAPI-1.4.1
PROJ: Rel. 4.5.0, 22 Oct 2006
Running tests
loader/Point.............. ok
loader/PointM.............. ok
loader/PointZ.............. ok
loader/MultiPoint.............. ok
loader/MultiPointM.............. ok
loader/MultiPointZ.............. ok
loader/Arc.............. ok
loader/ArcM.............. ok
loader/ArcZ.......... ok
loader/Polygon.............. ok
loader/PolygonM.............. ok
loader/PolygonZ.............. ok
regress. ok
regress_index. ok
regress_index_nulls. ok
lwgeom_regress. ok
regress_lrs. ok
removepoint. ok
setpoint. ok
simplify. ok
snaptogrid. ok
affine. ok
wkt. ok
measures. ok
long_xact. ok
ctors. ok
sql-mm-serialize. ok
sql-mm-circularstring. ok
sql-mm-compoundcurve. ok
sql-mm-curvepoly. ok
sql-mm-general. ok
sql-mm-multicurve. ok
sql-mm-multisurface. ok
geojson. ok
regress_ogc. ok
regress_bdpoly. ok
regress_ogc_cover. ok
regress_proj. ok
kml. ok
Run tests: 39
Failed: 0
Håvard
Paul Ramsey wrote:
> 1.3.4 is very close to release, but we can release it faster, with
> less intestinal distress, if we get some solid pre-release testing
> from folks. You can download the current SVN version directly from the
> downloads page, no SVN client required:
> http://postgis.refractions.net/download/postgis-1.3.4SVN.tar.gz
> If you want to also try the latest preparedgeometry enhancements,
> you'll need to upgrade your GEOS version to the SVN trunk before
> compiling and installing1.3.4SVN,
> http://download.osgeo.org/geos/geos-svn.tar.bz2
> Even if you don't, you should see some performance increases in 1.3.4,
> particularly in point-and-polygon predicate tests, and large joins
> using point-ant-polygon predicates.
> Let us know how it goes. We are particularly interested in any
> compilation difficulties or regression failures on less common unix
> variants (Solaris on Sparc, AIX on Power, etc)
> Paul
> postgis-users mailing list
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
