[postgis-users] 1.3.4SVN Testers Wanted
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 14 14:30:23 PDT 2008
make clean ; make
P
On Tue, Oct 14, 2008 at 2:11 PM, Chris Hermansen
<chris.hermansen at timberline.ca> wrote:
> I'm a willing 1.3.4 tester in principle, but the weakness of the flesh
> is upon me :-(
> I have Ubuntu 8.04 running on my machine, all patched up. Included is
> PostgreSQL 8.3 from the repositories (server development files included)
> and PostGIS1.3.3 also from the repositories.
> I downloaded the two tar files below. GEOS went in fine, including make
> test.
> Before building the PostGIS, I did an apt-get build-dep postgis and a
> few things came down from the repositories.
> OK, so here I am in the postgis1.3svn directory.
> ./configure runs very very quickly, with only one warning message:
> checking which template to use... linux
> configure: creating ./config.status
> config.status: creating Makefile.config
> config.status: WARNING: Makefile.config.in seems to ignore the
> --datarootdir setting
> config.status: creating config.h
> config.status: config.h is unchanged
> and then gives a status:
> SUMMARY
> HOST_OS: linux-gnu
> PGSQL: /usr/bin/pg_config
> GEOS: /usr/local/bin/geos-config (with C-API)
> (ldflags: -L/usr/local/lib)
> PROJ: prefix=/usr libdir=/usr/lib
> ICONV: 1
> PORTNAME: linux
> PREFIX: /usr
> EPREFIX: ${prefix}
> DOC: /usr/share/doc/postgresql-doc-8.3/contrib
> DATA: ${datarootdir}
> MAN: ${datarootdir}/man
> BIN: /usr/lib/postgresql/8.3/bin
> EXT: /usr/lib/postgresql/8.3/lib (\$$libdir)
> make runs even more quickly, here's the sum total:
> clh at TNRG048:~/src/postgis-1.3.svn$ make
> make -C lwgeom
> make[1]: Entering directory `/home/clh/src/postgis-1.3.svn/lwgeom'
> make[1]: Nothing to be done for `all'.
> make[1]: Leaving directory `/home/clh/src/postgis-1.3.svn/lwgeom'
> make -C loader
> make[1]: Entering directory `/home/clh/src/postgis-1.3.svn/loader'
> make[1]: Leaving directory `/home/clh/src/postgis-1.3.svn/loader'
> make -C utils
> make[1]: Entering directory `/home/clh/src/postgis-1.3.svn/utils'
> chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
> profile_intersects.pl test_estimation.pl test_joinestimation.pl
> make[1]: Leaving directory `/home/clh/src/postgis-1.3.svn/utils'
> Not much to test there :-(
> Any ideas?
> Paul Ramsey wrote:
>> 1.3.4 is very close to release, but we can release it faster, with
>> less intestinal distress, if we get some solid pre-release testing
>> from folks. You can download the current SVN version directly from the
>> downloads page, no SVN client required:
>> http://postgis.refractions.net/download/postgis-1.3.4SVN.tar.gz
>> If you want to also try the latest preparedgeometry enhancements,
>> you'll need to upgrade your GEOS version to the SVN trunk before
>> compiling and installing1.3.4SVN,
>> http://download.osgeo.org/geos/geos-svn.tar.bz2
>> Even if you don't, you should see some performance increases in 1.3.4,
>> particularly in point-and-polygon predicate tests, and large joins
>> using point-ant-polygon predicates.
>> Let us know how it goes. We are particularly interested in any
>> compilation difficulties or regression failures on less common unix
>> variants (Solaris on Sparc, AIX on Power, etc)
>> Paul
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Regards,
> Chris Hermansen mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
