[postgis-users] 1.3.4SVN Testers Wanted
Chris Hermansen chris.hermansen at timberline.ca
Tue Oct 14 14:37:36 PDT 2008
Mark Cave-Ayland wrote:
> Hi Chris,
> Since the tarball is generated after the SVN test build, you need to
> do "make clean" before "configure" and "make" to force a rebuild of
> the source tree.
I'll give that a try!
You aren't concerned about the message
> config.status: WARNING:  Makefile.config.in seems to ignore the
> --datarootdir setting
then?
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
