[postgis-users] Indices for ST_distance_sphere
Stephen Baillie steve at alliancesoftware.com.au
Tue Oct 14 17:31:34 PDT 2008
>What about 3112 (# GDA94 / Geoscience Australia Lambert) or 3577
>(Australian Albers), those should cover things fine, no?
Possibly, although I'm finding it hard to find hard data on what those
actually mean (let alone what other alternatives are supported by
PostGIS).  It looks like they still produce range distortion, which
answers to my previous question on this list gave me to believe would be
a problem for anything except true spherical distances.
Closer to the point, though, the choice of projection is of lesser
importance to my question than that of indexing.  PostgreSQL tells me
that the spherical distance calculations increase full table scan time
by about two-thirds when I use those as the where clause of my search
instead of using a lat/long bounding box, but my question is actually
about indexing before doing such distance calculations:
Is it possible to create an index that can be used to speed searches
based on distance from an arbitrary point, or should I just use a
lat/long bounding box?
Thanks,
Steve.
Stephen Baillie
Developer
Alliance Software
1/234 Whitehorse Road
Nunawading, VIC 3131
Australia
Ph:  03 9877 9921
Fax: 03 9894 2106
