[postgis-users] GeometryCollection after ST_Centroid(ST_Dump)
Obe, Regina
robe.dnd at cityofboston.gov
Wed Oct 15 05:57:01 PDT 2008
Birgit,
Ah that is weird - I've never seen it return a geometry collection
before. So what is the ST_AsText/ST_AsBinary of the first.
e.g.
SELECT
abdump.gid,
geometrytype(ST_Centroid(abdump.newgeom)) As geometrytype_centroid,
ST_AsText(abdump.newgeom) as astxtrep
FROM
(SELECT (ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom As
newgeom, a.gid, a.the_geom as a_the_geom, b.the_geom as b_the_geom
FROM bfn.test_mv_dlm07_dump a, bfn.test_mv_dlm07_dump b
WHERE ST_Overlaps(a.the_geom,b.the_geom)=true AND
Intersects(a.the_geom,b.the_geom)=true
) As abdump
WHERE abdump.gid = 119810
GROUP BY (ST_Centroid(abdump.newgeom)),
ST_Area(ST_Centroid(abdump.newgeom)),
ST_Perimeter(ST_Centroid(abdump.newgeom)), abdump.gid, abdump.newgeom;
By the way the result you sent doesn't match the query - its missing a
field and the labels don't match the query.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Birgit Laggner
Sent: Wednesday, October 15, 2008 8:45 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] GeometryCollection after
Hi Regina,
yes, that's true. The queries you took for testing work for me, too.
But if I try to run:
SELECT
ST_X(st_centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)) AS x_centroid,
ST_Y(st_centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)) AS y_centroid,
ST_Area((ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom) AS
area,
ST_Perimeter((ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom)
AS perimeter
WHERE ST_OVERLAPS(a.the_geom,b.the_geom)=true AND
INTERSECTS(a.the_geom,b.the_geom)=true
GROUP BY ST_X(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)),
ST_Y(ST_Centroid((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom)), ST_Area((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom), ST_Perimeter((ST_Dump(ST_Intersection(a.the_geom,
b.the_geom))).geom), a.the_geom, b.the_geom
ORDER BY x_centroid asc, y_centroid asc, area asc, perimeter asc;
I still get: error: Argument to X() must be a point.
The same happens when I formulate the query like you suggested in the
beginning:
SELECT
abdump.gid,
ST_X(ST_Centroid(abdump.newgeom)) As x_centroid,
ST_Y(ST_Centroid(abdump.newgeom)) As y_centroid,
ST_Area(ST_Centroid(abdump.newgeom)) As area,
ST_Perimeter(ST_Centroid(abdump.newgeom)) as perimeter,
abdump.newgeom
FROM
FROM bfn.test_mv_dlm07 a, bfn.test_mv_dlm07 b
) As abdump
GROUP BY ST_X(ST_Centroid(abdump.newgeom)),
ST_Y(ST_Centroid(abdump.newgeom)), ST_Area(ST_Centroid(abdump.newgeom)),
--a_the_geom, b_the_geom
ORDER BY x_centroid asc, y_centroid asc, area asc, perimeter asc,
abdump.gid asc;
Meanwhile, I am a bit confused, because I see no logic in what
happens...
Just to explain what I thougt, the problem might be:
When I run the following query:
SELECT
abdump.gid,
abdump.newgeom
FROM
) As abdump
I get this in return:
gid geometrytype
integer text
119810 "GEOMETRYCOLLECTION"
120217 "GEOMETRYCOLLECTION"
135837 "GEOMETRYCOLLECTION"
101408 "GEOMETRYCOLLECTION"
254497 "GEOMETRYCOLLECTION"
125720 "GEOMETRYCOLLECTION"
125731 "GEOMETRYCOLLECTION"
405587 "POINT"
412179 "POINT"
412179 "POINT"
405587 "POINT"
254497 "POINT"
242621 "POINT"
242621 "POINT"
254497 "POINT"
242621 "POINT"
254497 "POINT"
242621 "POINT"
254497 "POINT"
242621 "POINT"
254497 "POINT"
135850 "GEOMETRYCOLLECTION"
244155 "POINT"
254671 "POINT"
244155 "POINT"
254671 "POINT"
244155 "POINT"
254671 "POINT"
254671 "POINT"
244155 "POINT"
125742 "POINT"
135829 "POINT"
125742 "POINT"
135850 "POINT"
125731 "POINT"
135829 "POINT"
125742 "POINT"
125742 "GEOMETRYCOLLECTION"
135850 "POINT"
125742 "POINT"
134472 "GEOMETRYCOLLECTION"
133678 "GEOMETRYCOLLECTION"
126954 "GEOMETRYCOLLECTION"
135850 "POINT"
125731 "POINT"
135829 "POINT"
125742 "POINT"
135850 "POINT"
125731 "POINT"
135829 "POINT"
125742 "POINT"
135850 "POINT"
135829 "GEOMETRYCOLLECTION"
125731 "POINT"
135829 "POINT"
125742 "POINT"
135850 "POINT"
412179 "GEOMETRYCOLLECTION"
125731 "POINT"
135829 "POINT"
135850 "POINT"
125742 "POINT"
125731 "POINT"
135829 "POINT"
125742 "POINT"
135850 "POINT"
125731 "POINT"
135829 "POINT"
135829 "POINT"
125731 "POINT"
125742 "POINT"
135850 "POINT"
125720 "POINT"
135850 "POINT"
125731 "POINT"
135829 "POINT"
135850 "POINT"
125742 "POINT"
125742 "POINT"
135850 "POINT"
125731 "POINT"
135829 "POINT"
125731 "POINT"
135850 "POINT"
244155 "GEOMETRYCOLLECTION"
242621 "GEOMETRYCOLLECTION"
125731 "POINT"
135829 "POINT"
125742 "POINT"
135850 "POINT"
135837 "POINT"
125720 "POINT"
125720 "POINT"
135837 "POINT"
245042 "GEOMETRYCOLLECTION"
253750 "GEOMETRYCOLLECTION"
125720 "POINT"
135837 "POINT"
125720 "POINT"
135850 "POINT"
375311 "GEOMETRYCOLLECTION"
405587 "GEOMETRYCOLLECTION"
376289 "GEOMETRYCOLLECTION"
254671 "GEOMETRYCOLLECTION"
135837 "POINT"
125720 "POINT"
125720 "POINT"
404117 "GEOMETRYCOLLECTION"
135837 "POINT"
386583 "GEOMETRYCOLLECTION"
386466 "GEOMETRYCOLLECTION"
125720 "POINT"
135837 "POINT"
125720 "POINT"
135837 "POINT"
125720 "POINT"
135837 "POINT"
125720 "POINT"
135837 "POINT"
426566 "GEOMETRYCOLLECTION"
This is why I think, the ST_Centroid produces a geometrycollection.
Thanks again!
Regards,
Birgit.
Obe, Regina schrieb:
> Birgit,
> I just loaded up this data set you posted and tried doing
> SELECT ST_X(ST_Centroid(the_geom))
> FROM test_mv_dlm07_dump;
> Works perfectly fine for me. Even if you pass a geometry collection
to ST_Centroid, it would always return a point.
> To demonstrate
> SELECT ST_GeometryType(ST_Centroid(ST_Collect(the_geom))),
ST_AsText(ST_Centroid(ST_Collect(the_geom))) as full_cent
> Gives me this:
> "ST_Point";"POINT(3728516.33771743 5964986.31004069)"
> Are you saying the sample you posted when you do the above doesn't
work for you? If so, then there appears to be something wrong with your
install.
> What does
> SELECT postgis_full_version();
> return for you?
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS"
> Thanks,
> Regina
Birgit Laggner
> Sent: Wednesday, October 15, 2008 5:03 AM
> Hi Regina,
> thanks for your response! I tried the query you suggested and still
get
> the same result (error: Argument to X() must be a point), which is
> totally reasonable, regarding that the result of the ST_Centroid is
> still a GeometryCollection. My guess was, that this is caused by the
> fact that ST_Dump returns not only POLYGONs but also LINESTRINGs and
> POINTs. I thought, it could be that ST_Centroid has difficulties
> returning a centroid for points and linestrings. So, what I did so
far,
> was to split the query into one part, with which I just find all
> overlapping geometries without grouping or anything else, and one
part,
> which does the grouping including calculating of the centroid and
> everything else. And, between these two parts, I just delete all
> geometries that are LINESTRINGs or POINTs (I don't need them, I only
> need the polygons). At least, these queries run - I don't know yet if
> the result is correct...
> But, as I saw now, when I selected the data example you asked for (see
> attachement), that the GeometrieCollections don't occur at the
> linestring or point geometries as I expected. There seems to be some
> other problem, I don't understand...
> Here my new (working) query:
> CREATE TABLE bfn.mv_dlm07_olvg
> gid serial NOT NULL,
> gid_mv_dlm07 integer
> SELECT
AddGeometryColumn('bfn','mv_dlm07_olvg','the_geom','31467','MULTIPOLYGON
',2);
> ALTER TABLE bfn.mv_dlm07_olvg DROP CONSTRAINT
enforce_geotype_the_geom;
> INSERT INTO bfn.mv_dlm07_olvg (
> gid_mv_dlm07,
> the_geom)
> SELECT
> a.gid,
> (ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom AS the_geom
> FROM bfn.mv_dlm07_orig a, bfn.mv_dlm07_orig b
> INTERSECTS(a.the_geom,b.the_geom)=true;
> DELETE FROM bfn.mv_dlm07_olvg
> WHERE GeometryType(the_geom)='LINESTRING';
> WHERE GeometryType(the_geom)='POINT';
> gid_mv_dlm07 integer,
> x_centroid numeric,
> y_centroid numeric,
> area numeric,
> perimeter numeric
> SELECT
AddGeometryColumn('bfn','mv_dlm07_ol','the_geom','31467','MULTIPOLYGON',
2);
> ALTER TABLE bfn.mv_dlm07_ol DROP CONSTRAINT enforce_geotype_the_geom;
> INSERT INTO bfn.mv_dlm07_ol (
> gid_mv_dlm07,
> x_centroid,
> y_centroid,
> area,
> perimeter,
> the_geom)
> SELECT
> a.gid_mv_dlm07,
> st_x(st_centroid(a.the_geom)) as x_centroid,
> st_y(st_centroid(a.the_geom)) as y_centroid,
> st_area(a.the_geom) as area,
> st_perimeter(a.the_geom) as perimeter,
> a.the_geom as the_geom
> FROM bfn.mv_dlm07_olvg a
> GROUP BY st_x(st_centroid(a.the_geom)), st_y(st_centroid(a.the_geom)),
> st_area(a.the_geom), st_perimeter(a.the_geom), a.the_geom
> a.gid_mv_dlm07 asc;
> Regards,
> Birgit.
>> Birgit,
>> So you are saying ST_Centroid sometimes returns geometry collections.
>> Hmm I don't see how that is possible unless there is bug somewhere.
>> Can you provide an example of that.
> Is attached - these are the ones which return GeometryCollection after
> ST_Centroid. I had to remove the attributes because of privacy
reasons.
>> Regarding the below query - it
>> would be a bit easier to follow if you did a subselect first.
>> Something like
>> SELECT
>> abdump.gid,
>> abdump.objart_07,
>> abdump.cat_07,
>> FROM (SELECT (ST_Dump(ST_Intersection(a.the_geom,
>> b.the_geom))).geom As newgeom, a.gid, a.objart_07, a.cat_07,
a.the_geom
>> FROM
>> ) As abdump
abdump.objart_07,
>> abdump.cat_07, a_the_geom, b_the_geom
a.gid
>> asc;
>> Hope that helps,
>> Regina
>> Birgit Laggner
>> Sent: Tuesday, October 14, 2008 6:56 AM
>> Subject: [postgis-users] GeometryCollection after
>> Dear list,
>> I have a SELECT statement in which I try to group by the polygons
>> resulting from a self intersection. After I realized that I can't
group
>> by the_geom because this would group polygons which are only similar
but
>> not equal, I decided to group by the area, the perimeter and the x-
and
>> y-coordinates of the centroid of every polygon. The SELECT statement
I
>> wrote, worked so far for some test datasets and showed seemingly
>> reasonable results. But for at least one of my datasets, the
statement
>> does not work, because the ST_Centroid produces some
GeometryCollections
>> instead of POINTS. What could cause that problem and how can I solve
>> it???
>> This is my statement:
>> SELECT
>> a.gid,
>> a.objart_07,
>> a.cat_07,
>> b.the_geom))).geom)) as x_centroid,
>> b.the_geom))).geom)) as y_centroid,
>> ST_Area((ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom) as
>> area,
b.the_geom))).geom)
>> as perimeter,
>> (ST_Dump(ST_Intersection(a.the_geom, b.the_geom))).geom as the_geom
>> b.the_geom))).geom), a.gid, a.objart_07, a.cat_07, a.the_geom,
>> b.the_geom
a.gid
>> asc;
>> The ST_Dump results in POLYGONs, LINESTRINGs and POINTs.
>> Thank you for any help!
>> Regards,
>> Birgit.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
