[postgis-users] Memory problem with ST_Within
Shane Butler
shane.butler at gmail.com
Thu Oct 16 04:04:59 PDT 2008
Dear Birgit and List,
I am getting an out of memory error (see below) when doing a big query
that uses ST_Within(). This was described by Birgit on this list back
in August. Is there a solution?
Birgit, can you please explain the work around you mentioned on Aug 14:
http://postgis.refractions.net/pipermail/postgis-users/2008-August/020984.html
Any help would be greatly appreciated!
Kind Regards,
Shane
Some details of the error:
"ERROR: out of memory
DETAIL: Failed on request of size 32.
********** Error **********
SQL state: 53200
Detail: Failed on request of size 32."
My system info:
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS"
