[postgis-users] Your opinion on geocoding ?
Sufficool, Stanley ssufficool at rov.sbcounty.gov
Tue Oct 21 12:57:24 PDT 2008
I have been using a PL/pgSQL solution for geocoding to line segments. It
does no address parsing, but does the even/odd offset from line segments
after matching which was the most important factor for my application.
See attached. Please provide any input on what might be improved.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Stephen Woodbridge
> Sent: Tuesday, October 21, 2008 12:56 PM
> To: autisi at yahoo.com; PostGIS Users Discussion
> Subject: Re: [postgis-users] Your opinion on geocoding ?
> Smith Roman wrote:
> >   Hi,
> > Thanks, for your replies. I will like to ask for your own opinion as
> > regarding geocoding. Considering the limitations of my data. Which
> I'm not sure about what the limitation on your data are.
> Do you have house number ranges? Then you can use the method
> that Regina
> already suggested.
> If you do not have house number ranges then you have a bigger
> problem as
> roads with the same name might exist in adjacent towns, think
> Main St.
> Or a road might be multiple segments with the same name, but
> divided at
> the intersecting streets, think of 6th Ave and all its cross streets.
> > geocoding method do you think will be appropriate ? If possible, if
> > you
> > have links to papers on geocoding i will be grateful. Or do u think
> > geocoding the street names using the center point of the
> linestrings is
> > the most appropriate method ?
> To some extent, your geocoding methodology depends on two factors:
> 1) the quality and detail in the source data
> 2) what you want to do with the results like zoom a map or generate a
> route to a house, etc.
> Some other things you might want to consider are how to handle common
> abbreviation like Street, St., St, Avenue, Ave., Ave, Av.,
> Av, etc. The
> USPS publishes a list of common and acceptable abbreviation.
> You might also want to do some fuzzy search using something like
> soundex, or other phonic keys for words. Also how to deal with simple
> typographical error like "West wood" vs. "Westwood" or other common
> spelling errors.
> http://www.urisa.org/files/goldberg.pdf
> You might also want to read some of the articles listed in
> their References.
> Also notice on the bottom of this page:
> http://postgis.refractions.net/download/
> a TIGER GEOCODER, there has been a lot of discussion on this
> in the past
> in the list archives.
> Hope this helps,
>    -Stephen Woodbridge
>     http://imaptools.com/
> postgis-users mailing list postgis-users at postgis.refractions.net
Type: application/octet-stream
Desc: fn_offsetpoint.sql
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081021/f991f817/attachment.obj>
Desc: fn_geocode.sql
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081021/f991f817/attachment-0001.obj>
