[postgis-users] Out of Memory problem for large table by ST_Contains(..)
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 21 23:31:26 PDT 2008
This should be fixed when 1.3.4 comes out. An rc2 will be out tomorrow
you can try.
P.
On Tue, Oct 21, 2008 at 3:28 PM, John Zhang <johnzhang06 at gmail.com> wrote:
> Hello list,
> I am writing to seek your input on how to handle such an issue:
> I have a large table containing over 3 million polygons and a small table
> containing 53k points. My function is to identify whether a point in the
> table is Contained by a polygon in the polygon table. ST_Contains function
> is effectively used for this purpose (it takes about 2 seconds for given
> known polygon: "polyG && ptG AND ST_Contains(polyG, ptG)" is used where
> polyG an ptG are the geometries of the point an dpolygon). However, with a
> given pt, it crashes to run through all the polygons with the reason given
> "Out of memory for query" in about 300 seconds. I then tested with select
> count(*) of the polygon table, it takes 100 seconds as well. It seems there
> is something wrong in the database configuration. I could not figure out
> what is wrong there. Could anyone help on the issue? Any input would be much
> appreciated.
> Thanks in advance.
> John
> postgis-users mailing list
