[postgis-users] Roeck test
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 24 09:10:53 PDT 2008
Wouldn't the ratio of area to perimeter be a similar metric? Also,
wouldn't it be easier to just stop letting politicians draw their own
boundaries? :)
I wonder what the algorithm for minimum enclosing circle is...
(Short answer, no, because we don't have a min-circle routine.)
P.
On Fri, Oct 24, 2008 at 8:59 AM, Lee Meilleur <lee.meilleur at gis.leg.mn> wrote:
> Has anyone calculated the Roeck test using PostGIS? This is an area based measure that computes the ratio of the area of a polygon to the area of the minimum enclosing circle for the polygon. It's used to measure compactness of districts for redistricting applications, basically a way to test for gerrymandering. Thanks.
> Lee Meilleur
> LCC-GIS Office
> Minnesota Legislature
> 100 Rev. Dr. MLK Jr Blvd.
> 55 State Office Building
> St. Paul, MN 55155
> 651.296.0098 Fax: 651.297.3697
> http://www.gis.leg.mn
> postgis-users mailing list
