[postgis-users] Roeck test
Martin Davis
mbdavis at refractions.net
Fri Oct 24 09:40:29 PDT 2008
Wouldn't it be easier and more accurate to use the convex hull of the
polygon instead of the minimum enclosing ball? The CH will have smaller
area (i.e. be a tighter bound on the area covered by the polygon), so it
seems like it would give a more accurate basis for comparison.
Lee Meilleur wrote:
> Has anyone calculated the Roeck test using PostGIS? This is an area based measure that computes the ratio of the area of a polygon to the area of the minimum enclosing circle for the polygon. It's used to measure compactness of districts for redistricting applications, basically a way to test for gerrymandering. Thanks.
> Lee Meilleur
> LCC-GIS Office
> Minnesota Legislature
> 100 Rev. Dr. MLK Jr Blvd.
> 55 State Office Building
> St. Paul, MN 55155
> 651.296.0098 Fax: 651.297.3697
> lee.meilleur at gis.leg.mn
> http://www.gis.leg.mn
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
