[postgis-users] remove polygon from multipolygon
Frank Durstewitz frank.durstewitz at emporis.com
Fri Oct 24 10:25:38 PDT 2008
Hello list,
i must remove from multipolygon some polygons, for example remove all
polygons from "russia", where latitude of centroid of polygon is <= 0
(in this case the part of russia  which is near alaska).
I think this should be possible (ST_Dump...), but i cannot find any way
to do so.
Deleting the vertices by hand via a desktop gis is painfull slow and
will take ages - i tried this and need ~ 5 minutes for a very small
island of ~ 20 points... (i found no desktop gis where i can select
multiple vertices by a bounding box and delete them at once).
Thanks,
Frank
ST_Summarize gives
MultiPolygon[BS] with 1393 elements
  Polygon[] with 1 rings
   ring 0 has 15 points
   ring 0 has 25 points
