[postgis-users] Roeck test
Bruce Rindahl
rindahl at lrcwe.com
Fri Oct 24 11:25:38 PDT 2008
After a quick look at the links, couldn't a stored procedure (function)
be used here? I envision the input is a polygon, grab the outside ring,
explode the vertices's to get a set of points(all existing functions).
Then the collection of points could be looped through with the algorithm
described to return a center and radius which could then give a circle
(buffer).
Or am I on drugs here..
Bruce
Lee Meilleur wrote:
> Yes and yes to both questions, but the Roeck test is required by some states. And some states don't allow their politicians to draw their political boundaries.
> Thanks Martin, I'll test the convex hull and compare with the Roeck from our commercial software.
> Brent, thanks for the link, not sure if Paul will get the algorithm into the final release of PostGIS 1.3.4. I have two years to figure this out.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Martin Davis
> Sent: Friday, October 24, 2008 11:40 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Roeck test
> Wouldn't it be easier and more accurate to use the convex hull of the polygon instead of the minimum enclosing ball? The CH will have smaller area (i.e. be a tighter bound on the area covered by the polygon), so it seems like it would give a more accurate basis for comparison.
> Lee Meilleur wrote:
>> Has anyone calculated the Roeck test using PostGIS? This is an area
>> based measure that computes the ratio of the area of a polygon to the
>> area of the minimum enclosing circle for the polygon. It's used to
>> measure compactness of districts for redistricting applications,
>> basically a way to test for gerrymandering. Thanks.
>> Lee Meilleur
>> LCC-GIS Office
>> Minnesota Legislature
>> 100 Rev. Dr. MLK Jr Blvd.
>> 55 State Office Building
>> St. Paul, MN 55155
>> 651.296.0098 Fax: 651.297.3697
>> lee.meilleur at gis.leg.mn
>> http://www.gis.leg.mn
>> postgis-users mailing list postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081024/5ad2b9dd/attachment.html>
