[postgis-users] remove polygon from multipolygon
Frank Durstewitz, Emporis GmbH
frank.durstewitz at emporis.com
Fri Oct 24 12:07:33 PDT 2008
Hi Kevin,
yes, that looks good. I was on that way, but could not figure out, how
to get the geometry out of the dump rows.
Very nice this one, i have never seen this ".geom" (and still could not
find it somewhere in the docs?).
Many thanks!
Kindly regards, Frank
Kevin Neufeld am 24.10.2008 20:44:
> What about something like this:
> SELECT ST_Collect(geom)
> FROM (
> SELECT (ST_Dump(geom)).geom
> FROM my_multi_polygon_table) AS foo
> WHERE ST_Y(ST_Centroid(geom)) <= 0;
> Explode the multipolygon into individual polygons using ST_Dump, and
> ST_Collect the ones back up again where the centroid falls within some
> specification.
> -- Kevin
> Frank Durstewitz wrote:
>> Hello list,
>> i must remove from multipolygon some polygons, for example remove all
>> polygons from "russia", where latitude of centroid of polygon is <= 0
>> (in this case the part of russia which is near alaska).
>> I think this should be possible (ST_Dump...), but i cannot find any
>> way to do so.
>> Deleting the vertices by hand via a desktop gis is painfull slow and
>> will take ages - i tried this and need ~ 5 minutes for a very small
>> island of ~ 20 points... (i found no desktop gis where i can select
>> multiple vertices by a bounding box and delete them at once).
>> Thanks,
>> Frank
>> ST_Summarize gives
>> MultiPolygon[BS] with 1393 elements
>> Polygon[] with 1 rings
>> ring 0 has 15 points
>> ring 0 has 25 points
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
