[postgis-users] PostGis & pgRouting on Windows
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Oct 27 15:44:13 PDT 2008
Pablo Tutino wrote:
> Hi there,
> I'm Pablo Tutino, from Argentina.
> I've imported a Garmin .img DB files into polish format, then into
> shapes and finally into PostGis, using shp2pgsql.exe and QGIS.
> Now I have to create the directed graph up to use the pgRouting Library.
> The first error I found is that the create_graph_tables wrapper function
> is not included neither in pgRouting windows binaries nor sources.
> I found the wrapper on this link
> (http://postgis.refractions.net/pipermail/postgis-users/2007-April/015159.html).
> The problem is the DB's schema I was able to import to PostGis is not
> like the one in the example,
> http://www.davidgis.fr/documentation/pgrouting-1.02/.
> That schema includes
> id,source,target,x1,y1,x2,y2,cost,reverse_cost,oneway,length,rule,to_cost,
> but mine doesn't have x1,y1,x2,y2.
> How can I solve this?
> I mean:
> 1) How can I create a graph table from a schema containing only these
> fields:
> {gid integer NOT NULL,"LABEL" character varying(50),"TYPE" character
> varying(10),"LEVEL" character varying(9),the_geom geometry }?
> (the source, target and edge were created using assing_vertex_id function)
> 2) how can I use the correct create_schema_tables function?
> Thanks a lot
> Pablo
alter table mytable add column x1 float;
alter table mytable add column y1 float;
alter table mytable add column x2 float;
alter table mytable add column y2 float;
update mytable set
x1 = x(st_startpoint(the_geom)),
y1 = y(st_startpoint(the_geom)),
x2 = x(st_endpoint(the_geom)),
y2 = y(st_endpoint(the_geom));
vacuum analyze mytable;
Should probably do it.
-Steve
http://imaptools.com/
