[postgis-users] How to access PostGIS directly from R (rgdal)
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Oct 29 01:55:44 PDT 2008
Hi Brent,
Perhaps this link could get you further
http://article.gmane.org/gmane.comp.lang.r.geo/1428
Jan
pcreso at pcreso.com wrote:
> Thanks Regina,
> PL/R is not a solution in this case. We want to be able to
> load PostGIS geometries as R objects, not return the result
> of an R function applied to PostGIS data via SQL.
> The idea is to use PostGIS to manage all the data &
> have R access it natively. We can then have one PostGIS
> cluster to maintain, and our QGIS/gvSIG/JUMP/uDIG users can
> access it natively, Mapinfo & ESRI users can access it
> via WMS/WFS as appropriate, GMT users can use ogr2ogr &
> R users can use rgdal.
> It will be pretty neat if we can get it all working
> smoothly. We are also looking at using PostGIS as our ESRI
> geodatabase, but still providing access via the same
> protocols to all the other apps. Much better than
> shapefiles, etc being passed around...
> Cheers,
> Brent Wood
> --- On Wed, 10/29/08, Paragon Corporation
> <lr at pcorp.us> wrote:
> > From: Paragon Corporation <lr at pcorp.us>
> > Subject: RE: [postgis-users] How to access PostGIS
> > To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net>
> > Date: Wednesday, October 29, 2008, 2:13 PM
> > Brent,
> > I suppose calling RGDAL from PostgreSQL is not an
> option?
> > http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut03
> > Hope that helps,
>>> Regina
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net]
>> On
>>> Behalf Of
>>> Sent: Tuesday, October 28, 2008 8:15 PM
>>> To: PostGIS Users Discussion
>>> Subject: [postgis-users] How to access PostGIS
>> directly
>>> from R (rgdal)
>>> Hi,
>>> This may be better suited to the R or GDAL lists, but
>> I
>>> don't frequent
>>> those, so I'll try here first.
>>> We have PostGIS databases we are looking to use behind
>> a
>>> WMS/WFS server & as
>>> a generic spatial data repository for my organisation.
>>> We have a lot of R users, & I'd like to be
>> able to
>>> have them able to access
>>> the topo data (coastlines, roads, rivers, lakes,
>> cities,
>>> etc) for use with
>>> some of our R mapping functionality.
>>> I had hoped rgdal would support this, but having
>> installed
>>> it, it does not
>>> support Postgres/PostGIS databases as an OGR source.
>> We
>>> could use something
>>> like shapefiles as an intermediate format if there is
>>> nothing better, but
>>> I'm hoping for some pointers in how to enable
>> Postgis
>>> access directly.
>>> We can use ODBC, via dbi, etc, but this means
>> reinventing
>>> ways of
>>> interpreting geometry datatype data.
>>> Does anyone have any suggestions?
>>> Thanks,
>>> Brent Wood
>>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
