[postgis-users] Live PostGIS Edit tool?
Sufficool, Stanley ssufficool at rov.sbcounty.gov
Fri Oct 31 10:43:42 PDT 2008
Hmm, I guess I'll try this again with uDIG then. I ran into some problem
with uDIG and just assumed it was sucking the entire table to memory and
then resaving it.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: Friday, October 31, 2008 10:07 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Live PostGIS Edit tool?
> uDig doesn't checkin/checkout, it works directly on the
> records one at time.
> P.
> On Fri, Oct 31, 2008 at 9:58 AM, Sufficool, Stanley
> <ssufficool at rov.sbcounty.gov> wrote:
> > So far all the tools I have worked with (OpenJUMP, uDIG)
> use a check
> > out, check in process on PostGIS to update geometries. This is
> > impractical and sometimes impossible with these tools when dealing
> > with hundreds of thousands of records to re-write the
> entire table to
> > update one linestring/polygon.
> > What I am looking for is a live editor that will post the
> changes to
> > only the geometry row I am working with instead of caching the
> > changes. I can record the versions of this data for UNDO at the
> > database with triggers, so the check-in/check out is
> irrelevant at the
> > client since I can roll back any user changes to any point
> in time at
> > the db layer.
> > Anyone know of such a tool or am I going to have to roll my own?
> > Stanley Sufficool
> > Systems Analyst
> > San Bernardino County
> > 909-387-2102
> > P  Please consider the environment before printing this
> e-mail or its
> > attachment(s)
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
